Impala Police package
Hello, I have a 3900 V6 with the engine oil cooler in the radiator. The manual reads oil cpacity at 5.1 quarts. The max I put is about 4. Is there a plug on radiator I'm missing??? This Impala had 35000 miles when purchased as is like NEW. Haydad
the volume of oil remaining in the oil cooler is less than a cup of coffee. If you removed the line even with the system full of oil you probably wouldn't get much draining out.
Do your oil changes regularly (don't wait untill the oil life monitor expires) and drain while the oil is hot and you will be fine.
