Throttle Body, Engine Power Reduced
I have a 2011 Chevy Impala which keeps going into limp mode. I have replaced the throttle position sensor as well as the throttle body. The car will run fine for a week or so and then out of nowhere, it goes into limp mode. What is the recall number for this issue? I can not throw more money away for this same problem.
It comes and goes. After driving for a while the check engine light resets itself. Throttle body, gas pedal and starter. Only use 93 fuel. Brake system.
It's been so many the last I got tonight was the throttle body needed to be relearned. But I know when that is taken care of it will be back to normal every other week. Never got a fuel system code. It also now starts to give an anti-theft system code.
mattsauto
October 17th, 2010 3:46 PM
