2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Throttle Body, Engine Power Reduced
Old Feb 1, 2021 | 5:14 PM
Sylwilk83's Avatar
Default Throttle Body, Engine Power Reduced
I have a 2011 Chevy Impala which keeps going into limp mode. I have replaced the throttle position sensor as well as the throttle body. The car will run fine for a week or so and then out of nowhere, it goes into limp mode. What is the recall number for this issue? I can not throw more money away for this same problem.
Old Feb 1, 2021 | 7:56 PM
kevinkpk's Avatar
Is this a consistant issue as in the time frame this occurs? Next, when did it start, and besides the tps change what else has been done?
Old Feb 1, 2021 | 8:04 PM
Sylwilk83's Avatar
It comes and goes. After driving for a while the check engine light resets itself. Throttle body, gas pedal and starter. Only use 93 fuel. Brake system.
Old Feb 1, 2021 | 9:03 PM
kevinkpk's Avatar
Are you able to retrive the dtc?
Old Feb 1, 2021 | 9:25 PM
Sylwilk83's Avatar
It's been so many the last I got tonight was the throttle body needed to be relearned. But I know when that is taken care of it will be back to normal every other week. Never got a fuel system code. It also now starts to give an anti-theft system code.
StephVannah'sMom
Nov 21, 2017 10:25 AM
Bjoiner16
Oct 3, 2017 6:33 PM
scatgo
Aug 5, 2017 1:50 PM
mattsauto
Oct 17, 2010 3:46 PM
bmcdon
Jan 21, 2008 3:29 PM
