2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Traction Control Servicing / ABS Light
Old May 20, 2010 | 12:37 PM
Catnbutterfly's Avatar
Post Traction Control Servicing / ABS Light
I have a 2001 Impala. Lately the service traction control light has been coming on along with the abs light. When that happens the traction control off also comes on. I had my brakes looked at, (although I don't know if they checked the abs or not) and was told they were fine. The lights only come on when barely moving either right or left in a parking lot and stopping from a very slow rate of speed. Is this possibly a sensor?
Old May 20, 2010 | 3:06 PM
jondoe28's Avatar
Check and clean the connections behind the wheel, where the wire comes up
from the hub, and snaps together by the strut. Every time mine acts up, cleaning it
will give another year of trouble free service before it needs to be cleaned again.
If that doesn't work, then look at the more expensive fix. Let me know if this works for you.
Old May 23, 2010 | 2:57 AM
2000sdime's Avatar
does your speedo act retarded too like say your goin 110mph while in park and what not
Old May 24, 2010 | 6:02 AM
Post Traction Control / ABS Light
My husband will checking the hubs soon to see if they need to be cleaned. And no my speed o meter hasn't been acting strangely. At least not yet. I have had to replace the gas pump device because the gas gauge had quit working.
Old May 25, 2010 | 4:06 PM
2000sdime's Avatar
The Traction Control/ABS issue is common and is either a bad wheel hub/wheel speed sensor, or a bad speed sensor harness
RJK
Jan 29, 2024 5:56 PM
idk2050
Mar 24, 2015 9:32 AM
r3z
Mar 24, 2008 11:35 AM
