2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
update on the bad bearing replacement
Old Apr 16, 2023 | 6:01 PM
Nar DeMexico's Avatar
Default update on the bad bearing replacement
well the consensus was that I was sent the wrong part, since it had no electrical connector, but, I figured, "well I can remove the old bearing and clean it up and everything, maybe that will be hold it for a while."
so I can't get the rotor off. I had a mechanic neighbor helping me after I reached the impasse, and we find a broken little bolt in a previously-thought unused t-30 cavity. He drilled it out, big bore, massive hole, no trace of anything.
still won't budge. He is confused. What gives?
Old Apr 17, 2023 | 1:30 AM
oilcanhenry's Avatar
Might use a Victor Wrench to heat it up some.
Old Apr 17, 2023 | 8:04 AM
Post a picture of it. Replace it, you can't service it.
Old Apr 17, 2023 | 1:57 PM
spray some penetrating fluid in the back of the rotor in the space created with the caliper removed...spray and rotate the hub to cover the hub and rotor. Then hammer it off with a soft face dead blow hammer or steel hammer onto a block of wood placed on the rotor face.
Old Feb 28, 2024 | 10:25 AM
If you live in a state with safety inspections this truck will not pass even with a patched crossmember.
Nar DeMexico
Apr 16, 2023 1:42 PM
hogbiker
Apr 15, 2022 6:32 AM
yzer69
Astro
Oct 5, 2014 10:22 AM
mharrelson
Dec 6, 2011 10:57 AM
waycon
Jul 2, 2006 2:31 PM
