K5 Blazer 1969-1994
Platform: Truck, GMT 400
Click/pop noise
Old Nov 22, 2024 | 11:33 AM
cjcatcher13's Avatar
Default Click/pop noise
I am currently having an issue with my transmission, I believe. If you have time to check this video I would appreciate it. The truck is a 1978 k5 blazer with a sbc350 and a th350 turbo trans. It makes a single pop noise at certain speeds after warmed up (10 min of driving). It started when I was pulling a trailer. It would click upon immediate acceleration and kill the engine. Without towing it still clicks but usually at 30 and 50. I have replaced the modulator, and inspected the governor and accumulator; all appear fine. The transmission pan did have a gritty sludge layer at the bottom but nothing looked fresh. The fluid is pretty clean, but does have a slight burnt smell. Should I put a "trans fix fluid" to see if the clutch plates are worn, or does this sound more like a torque converter? Any help is appreciated.
Link to video: https://youtube.com/shorts/TPz5IbBFeBo?feature=share
Dezrcr822
Mar 30, 2020 11:19 PM
2000suburbanjeff
Nov 14, 2014 7:59 PM
idrivea1991avanti
May 3, 2014 8:10 PM
7thGenTexan
Aug 26, 2012 8:05 PM
An89Chevy
May 13, 2007 9:26 AM
