K5 Blazer 1969-1994
Platform: Truck, GMT 400
floor shifter
Old Dec 29, 2009 | 10:58 PM
86k5's Avatar
Default floor shifter
has anybody installed or know how hard it would be to install a floor shifter? I am new to the whole 4x4 scene i used to drive little imports.. the column shifter is a little wierd and i think it would be handy to install a floor shifter.
if anybody has any links or could walk me through it, i would appreciate it. (i was going to use the tci streetfighter)
i have an 86 k5 4x4 350 im guessing its the 700r4 trans
here is a link to myspace with pics needs a some work..
thanks
Old Dec 30, 2009 | 10:40 AM
myotherchevyisablazer's Avatar
<HR>
Lokar Column Shift hook-up Parts
Column Shift Linkage
ACA-1800 shown
Adjustable Billet Column Arm Kit for TH350/400/700...........ACA-1800
Adjustable Billet Column Arm Kit for C4/C6...........ACA-1801
Adjustable Billet Arm only TH350/400/700...........ACA-1802
Adjustable Billet Arm only for C4/C6...........ACA-1803
ACA-1802 shown
<HR>Lokar Floor Shifters
Automatic Transmission Shifters
All shifters available in 23", 16", 12", 10", 8" and 6" lengths. Brushed aluminum original Mushroom, black anodized mushroom and Hi-Tech Lokar tapered ***** available for all shifters. Specify Length and Standard **** style when ordering. Lokar boot rings and indicators are also available. Call for pricing on these products.
From Left to Right, Standard Shift, Nostalgia 23" tall shifter and Nostalgia 16" tall shift
this might give you a base to start from
http://www.progressiveautomotive.com/Lokarshifter.htm
red
Old Jun 20, 2010 | 10:07 AM
frickenbored's Avatar
Its super easy to put in a floor shifter, I used the B&M z-gate shifter for my 1988 k5 (but I custom made a new shifter handle) The B&M shifter are very easy to install because they dont use any linkages, all the shifting is done with a cable. It took me like an hour to mount it all and get it adjusted right. Whatever shifter you get make sure it has a reverse lock out. Heres a pic of my floor shifter:
If you wanna see how its hooked up at the transmission let me know and I can go take a pic of it.
Old Jun 21, 2010 | 10:13 AM
86k5's Avatar
yea if yu could that would be cool, thanks
johnmcgrady35
May 26, 2021 12:34 AM
white bear
Jul 5, 2011 11:02 PM
squarepeg
Apr 8, 2010 7:18 PM
Speedy650
Jan 30, 2010 10:46 PM
