Chevrolet Malibu
2000 malibu won't start
Old Aug 2, 2015 | 8:25 PM
fixitup44's Avatar
Unhappy 2000 malibu won't start
need some help here .please....have a 2000 Malibu ls 3.1 motor..followed a conversation a while back but can't find it... I have no fuel pressure....but in following previous thread new fuel pump didn't fix it ... they then talked about the switch not supplying the 12 volts..only 6 at the engine fuse block ....how can I determine if the swtich or pump is the problem ? thanks..ready to start working on it again....
Old Aug 22, 2015 | 9:27 PM
malibuboo's Avatar
I hope you got it solved by this time. If you fixed it, what was the cause? First check all fuses.
The oil pressure switch sometimes has a connection with the fuel pump. If it does, the oil pressure sensor cuts off the power to the fuel pump if it senses no or low oil pressure.
I was wondering if you had any trouble codes come up. Did the check engine light come on?
Did you have a code reader read the codes?
It's possible that a crankshaft or camshaft position sensor is giving a code to the computer and shutting down the power to the fuel pump.
Old Aug 25, 2015 | 5:23 PM
60wt's Avatar
if your theft light is blinking it's the passlock sys. to overide turn key to on, wait-- it takes aprox 10 minutes and the theft light will stop blinking and stay on, then turn ignition off then normally start the car…
ZChevyAK
Nov 13, 2015 6:45 PM
pmccrite
Sep 26, 2015 11:29 PM
tobixforever
Feb 26, 2015 2:47 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
