Chevrolet Malibu
2005 malibu maxx 3.5 ac compressor
Old Feb 22, 2020 | 2:39 PM
retired man's Avatar
Default 2005 malibu maxx 3.5 ac compressor
Does anyone have the instructions on how to replace ac compressor on a 2005 Malibu maxx 3.5 liter engine? It looks like a challenge. Thanks
Old Feb 23, 2020 | 8:15 AM
oilcanhenry's Avatar
I'm an expert on auto A/C systems. How much do you know about automotive A/C systems? If you have worked on a compressor before, I can likely help you out.
Old Feb 23, 2020 | 8:42 AM
Thanks for the reply. I have been doing my repairs for a long time. I am a retired engineer. Me and my Son own a small car lot in S.C.. We do a lot of repairs to save money. This car is making noise at the ac clutch and I need to replace the ac.Any help would be appreciated. Thanks
Old Feb 23, 2020 | 2:38 PM
Looks like the Malibu Maxx 3.5 V6 is mounted down low on the motor. I'd jack it up, work from the bottom. Looks like three hold-down bolts going into the block to me. Does the system have any pressure left?
Old Feb 23, 2020 | 3:44 PM
Yes it still has pressure. I have read that I need to remove the headlights and the front bumper to gain asses. I was hoping that I could find a write up on it with what all has to be removed. Thanks
Old Feb 23, 2020 | 5:50 PM
I don't envy you all that. If the A/C is working properly, you may just need a new magnetic clutch, but I'd wager you'd still have to take off all those parts.
Old Feb 23, 2020 | 5:55 PM
After looking underneath and from the top it looks like the inner fender well,bumper,headlights,radiator,and condensor will have to be removed. Any suggestions will be appreciated.
Old Feb 24, 2020 | 7:05 AM
Can you show us any pics or vids? I can't find anything on the Malibu Maxx online. In regards to the front body work
Old Aug 4, 2025 | 2:34 PM
Chucky733's Avatar
Smile 20005 Malibu Maxx Compressor R&R
I'm a shade tree mechanic and I have one tree.
This is the procedure for just the compressor R&R on a 2005 Chevrolet Malibu Maxx
Removal
-Take a pic or make a drawing of the serpentine belt pully positions.
-Wear mechanic gloves you will cut your hands if you don't.
-Loosen the serpentine belt using a 3/8 ratchet or breaker bar.
Remove the air intake hose. 10 mm bolt and 5/16 for the clamps.
-Raise the car with a floor jack and remove the RF wheel. Place a jack stand under it for safety. 19 mm socket for lug nuts
-On the lower front inner fender plastic cover remove the push fasteners and X-mas fasteners using a trim tool. This will allow access for compressor removal. It's very tight but doable. Save the fasteners.
-From the front of the engine bay on the compressor disconnect the electrical plug and remove the 2 bolts.15 mm There is a dog bone spacer that will fall when you pull the bolts so hang onto it. for the install.
-Underneath the car remove the 3rd bolt from the compressor and let it rest in the engine bay. 15 mm
-From the front, remove nut on the A/C hoses at the compressor. 13mm
- Wiggle, pull and cuss until you get the compressor out of the side front hole in the fender well. Take a bow your halfway there.
Install
-From the RF wheel side wiggle push and cuss until you get the new compressor back into the engine compartment.
-Replace the O-rings on the A/C hoses at the compressor and tighten nut. 13mm
-Reconnect the electrical plug into the compressor.
-From the engine bay install the compressor 15 mm bolts with the dog bone spacer in place. Do not tighten just get some turns on the bolts.
-From underneath install the 3rd compressor bolt and snug it.
-From the engine compartment tighten the 2 compressor bolts.
-From underneath tighten the 3rd compressor bolt.
-Install the serpentine belt. Recommend a new one. You're doing it anyway.
-Install lower fender inner plastics using the saved push fasteners.
-Install RF tire and torque lug nuts to 100 ft lbs.
-Pull a vacuum on the A/C system.
-Start engine, turn on A/C system and Install 17oz R134-A Freon.
-Check for leaks and cold air at the air vents.
-Clean greasy hand prints on the car and take a ride and use the recirculate button on dash. Should be really cold.
Your have completed the R&R for the A/C compressor so take a bow and pat yourself on the back.
Good luck and Hope this helps.
lancons23
Jul 18, 2017 2:15 PM
s34n
Sep 7, 2014 11:10 AM
mobilemodding
Apr 3, 2009 3:21 PM
Skrappi
May 12, 2008 4:28 PM
