Chevrolet Malibu
AC/Heat control problems
Old Dec 28, 2006 | 8:01 PM
malibuman76's Avatar
Default AC/Heat control problems
I have been having a couple of problems with my AC/HEAT control module. My Fan setting for 1, and 2 do not work and recently my rear defroster doesn't work ether. Does anyone know what I will have to do to fix these problems?
Old Dec 29, 2006 | 12:54 AM
Dieselcaddy's Avatar
Default RE: AC/Heat control problems
what year?
Old Dec 29, 2006 | 8:04 PM
Its a 1997 with the 3.1 liter V6.
Old Dec 30, 2006 | 5:25 PM
313hitman's Avatar
mine is doing the same thing. the a/c and heat only work when the dial in on 3 and up..
Old Dec 30, 2006 | 9:53 PM
Its strange that its donig this. I actully read alot about other people having the same problem but know one has a fix for the problem, its very odd i think.
Old Dec 31, 2006 | 10:12 PM
golfer's Avatar
It's not strange at all ... fairly common problem ...the fix for the fan only working on high speed is the voltage divider circuit ( resistor coils ).
For the rear defroster check the fuse first if that's OK then use a multimeter to check for voltage at the back window contacts , also with your multimeter check the filament grid for continuity.
Old Jan 1, 2007 | 12:43 AM
This might sound stupid but where is the resistor coils and how would I go fixing it.
Old Aug 14, 2007 | 3:54 PM
MalibuRich's Avatar
Have you removed your A/C control module and pulled the back cover off your fan speed control switch to see if the contacts are dirty?
Old Aug 14, 2007 | 4:50 PM
Actually MalibuRich, I haven't even looked at it. My AC doesn't work so I haven't used the control since winter for the heat. I have found a How-To on this one a Malibu forum. I will be replacing the resistor sometime this fall. I will check the contact before I purchase a new resistor and see if that is the problem. Thank you.
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
