Chevrolet Malibu
Auto stop malfunction/ Auto stop turns car completely off
Old Mar 8, 2025 | 12:25 PM
missparker2025's Avatar
Default Auto stop malfunction/ Auto stop turns car completely off
Hello I have a 2015 Chevy Malibu 2.5LT that malfunctions when I’m at a stop sign or red light. The car stops and the auto stop kick in and once I take my foot off the brake the car has a hard time starting back up, then eventually will turn completely off. I have to put the car in park and restart the engine completely. Does anyone have this issue or know what could be causing it? It’s getting annoying, I’ve had both batteries replaced and everything else is fine. I just can’t deal with this issue anymore. Thank you in advance!
Old Mar 9, 2025 | 8:12 AM
Moonwink's Avatar
The first thing I'd do is have both the batteries tested. Treat them as a "set." If one isn't in good shape, replace them both to avoid problems coming back right away. The computers depend on good batteries or they start doing strange things. Auto stop/start is one of the indications the batteries are in poor condition. If the batteries test good, have it scanned with a good scanner and let us know what they are.
Old Mar 11, 2025 | 12:24 PM
hello, I’ve had both batteries replaced and check but I’ll get the 2nd one checked again. The front battery was just replaced under warranty, the auxiliary battery I’m going to take it by Auto Zone today to have it scanned again. Then I’ll give an update, but as far as I’ve been told both batteries are in good shape.
Old Mar 11, 2025 | 12:32 PM
Rednucleus's Avatar
And make sure terminal connections are clean and tight!
Old Mar 11, 2025 | 12:51 PM
Moonwink's Avatar
The body grounds have been reported to cause a lot of problems. Make sure they're all good and no corrosion.
Old Mar 11, 2025 | 1:26 PM
Default Both batteries are good
Both batteries have been checked and they’re both in good condition. I will check the other suggestions out and will report back. Thank you all for your responses.
Old Mar 12, 2025 | 11:58 AM
Moonwink's Avatar
Related:
https://www.chevymalibuforum.com/posts/944109/
"I have 2013 2.5. It was stalling at stops or when I put in reverse. I replaced the MAF and both O2 sensors, now it runs perfect. No more stalling."
jaleahah
Mar 8, 2025 11:31 AM
LanceCothan
Nov 19, 2024 6:07 PM
sk8rkidd2435
Sep 8, 2022 12:01 AM
jrkuhler
Apr 6, 2022 8:18 PM
crazy1
May 11, 2017 9:59 PM
