Chevrolet Malibu
Buzzing noise increases with speed
Old May 25, 2014 | 2:00 PM
Hopp1234's Avatar
Default Buzzing noise increases with speed
I currently have a 2009 chevy malibu hybrid. Just recently I noticed when I hit speeds of about 30mph there is a buzzing noise coming from somewhere around the engine. As I increase in speed the noise gets faster and louder. There is no change in the noise when I turn the car left and right so I don't think it is a wheel bearing. I need knew tires but I don't believe it is the tires humming. Anyone else have this problem
Old May 25, 2014 | 4:10 PM
Welcome to the the forum
Could be an exhaust leak
Maybe a loose heat shield
possible wind noise from the strips around the windshield
Might check the air cleaner and make sure its secure
Do you have a bug deflector installed?
Just some ideas
Old May 26, 2014 | 3:46 PM
Hopp1234's Avatar
When the car is in park and the engine is revved it is normal and I can't see any holes in the exHaust. The noise gets faster and louder as you speed up and will slow when you slow down. Possibly a bearing in the transmission? I have no idea.
Old May 26, 2014 | 3:56 PM
Hopp1234's Avatar
No bug deflector
Old May 31, 2014 | 2:57 PM
The-AF-Chief's Avatar
I had a similar noise and it was the power brake booster pressure tube hitting against the firewall. GM has a service bulletin on it.
Old Jun 3, 2014 | 8:50 PM
Official GM Rep
Hi Hopp1234,
I see that you are experiencing concerns with a buzzing noise in your 2009 Chevrolet Malibu. If you'd like to take your vehicle into the dealership, I'm happy to assist with scheduling an appointment. Please send me a private message here on the site. Thank you!
Andraya
GM Customer Care
Old Aug 7, 2017 | 3:04 PM
Ben Z's Avatar
I'm experiencing this same issue in my 2012 Malibu LT. I see the OP didn't come back with what it was. Any ideas or suggestions?
mtm6042
Avalanche
Jul 22, 2021 6:20 PM
mpunt
Sep 20, 2012 5:13 PM
smcolin
Jun 8, 2012 4:00 PM
larryboy58
10
Sep 5, 2009 7:24 AM
cvpi71
Mar 8, 2009 9:09 PM
