Chevrolet Malibu
orifice tube
Old Aug 12, 2012 | 8:02 PM
tthreat's Avatar
Default orifice tube
Im trying to locate the orifice tube on a 2006 malibu anybody know where it is?
Old Jun 23, 2016 | 7:23 PM
James Rupinski Sr.'s Avatar
At firewall on high pressure line, you'll notice flare in pipe.
Old Jun 23, 2016 | 9:53 PM
pretty sure 06 mailbu do not use orfice tubes. check your condenser...if it has a cylinder next to it, receiver dryer...orfice tubes are not used.
the metering device would then be a thermal expansion valve located where both high and low a/c lines connect at the fire wall.
Old Jun 24, 2016 | 9:40 AM
Tech2, I just removed orifice tube (NOT ORIFICE TUBE, FILTER) to check for debri. Replacing compressor next. Made ever separation possible from condenser back and wound up at firewall. Lower line has flare and orifice tube going to high side. At end of week will supply pics when replacing new orifice tube and comp.
Old Jun 24, 2016 | 1:54 PM
what engine size do you have? I looked up service info for a v6 either 3.9 or 3.5L IIRC.
I believe you. pics may help the op
Old Jun 24, 2016 | 3:49 PM
2.2 L vin# fourth letter Z , 2006 Chevy Malibu LT 4 dr Sedan
Old Jun 27, 2016 | 12:30 PM
Pics
Last edited by James Rupinski Sr.; Jun 28, 2016 at 1:18 PM. Reason: This system DOES NOT have an orfice tube. What is showing in picture is actually just a FILTER...
Old Jul 3, 2016 | 2:00 PM
can't ask for more than that!
keelklan
Jun 8, 2024 7:31 AM
tom5170
Nov 30, 2010 11:42 PM
dan32
Jul 3, 2010 3:14 PM
andyjf80
Apr 18, 2010 2:51 PM
samger2
Aug 7, 2009 12:47 PM
