Platform: A-, G-, & W-body
2000 Monte Carlo LS wiring issues
Old Jan 23, 2010 | 6:23 PM
bmxr22808's Avatar
Exclamation 2000 Monte Carlo LS wiring issues
I just bought a 2000 monte carlo from a friend that had it sitting in his garage. It was running and I went to check the trans fluid since it seems to be shifting a little hard, and when I went to put the dip stick back in I got a shock from where the dip stick sits. I tried 2 more times and wasnt able becaue I kept getting shocked. I eventually turned the car off and and put it back in. I was wondering why I got a shock from it? And also when it is at lower rpms it shows as if the alternator is going but I replaced that and I still have problems of it seeming to not have enough power. Any advice will be greatly appriciated. Thanks
Old Feb 7, 2010 | 10:37 AM
taz3's Avatar
The only thing that could shock you to the point that you would feel it, would be the coil or ignition wires, start the car up in a dark area and look for spark jumping to the dipstick.
Old Feb 23, 2010 | 12:11 AM
02MonteSS's Avatar
Default electrical issues
i have an 02 monte ss, i built up the motor and over time for some reason the battery will kill itself and i have to either jump it or charge it up.. also, fog lights wont turn on, checked all relays fuses the bulbs and checked the wire endings with volt meter.. when i hit the switch nothin happens, and ideas?
spencerdad2010
Aug 9, 2012 4:53 PM
Amy Mayfield Anderson
May 21, 2012 7:06 PM
Jason R
Jul 5, 2011 2:31 AM
bobobeware
Dec 17, 2009 3:10 AM
WyattAult
Aug 6, 2009 7:13 PM
