Platform: A-, G-, & W-body
4T65E transmission four speed auto non HD for now, 2005 Chevy Monte Carlo need specs
Old May 3, 2013 | 12:30 AM
Brok's Avatar
Default 4T65E transmission four speed auto non HD for now, 2005 Chevy Monte Carlo need specs
Does anyone know the torque specifications for the valve body side 4T65E, need all them leading back the the driven sprocket? Plan to replace all solenoids. Check any problems lying back and then open the differential side and extension housing and make sure everything is within rated areas that GM states and nothing is burnt up. Also plan to upgrade this to an HD model as if it is down then I minus well fix and take the time to make it nice and right. Does anyone also know any good sites other than Ebay, Amazon, Tripleedgeperformance or that, that can offer good prices on transmission (trans-axle) parts? Any advice is appreciated greatly.
These are the ones they gave me at TripleEdgePerformance.com just wondering if anyone knows if these are accurate or not?
Below are the Torque Specs for the 4T65E
<table style="width: 670px; height: 874px; text-align: left;" border="0" cellpadding="1" cellspacing="1"><tbody><tr> <td>Description</td> <td>Thread Size </td> <td>Lb.Ft.</td> <td>Lb.In.</td> </tr> <tr> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Bottom Pan Bolts (mid 98+)</td> <td> M6 X 1.0 X 17</td> <td> 10</td> <td>
</td> </tr> <tr> <td> Side Cover Bolts</td> <td> M8 X 1.25 X 25</td> <td> 18</td> <td>
</td> </tr> <tr> <td> Side Cover Bolts ( Torx head )</td> <td> M8 X 1.25 X 21</td> <td> 18</td> <td>
</td> </tr> <tr> <td> Final Drive Housing Bolts</td> <td> M10 X 1.5 X 35</td> <td> 26</td> <td>
</td> </tr> <tr> <td> Forward Servo Cover Bolts</td> <td> M6 X 1.0 X 20</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Vehicle Speed Sensor Bolt</td> <td> M8 X 1.25 X 12</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Drive Sprocket Support Bolts</td> <td> M8 X 1.25 X 24</td> <td> 18</td> <td>
</td> </tr> <tr> <td> Manual Shaft Detent Lever Nut</td> <td> M10 X 1.5</td> <td> 23</td> <td>
</td> </tr> <tr> <td> Line Pressure Test Plug</td> <td> 1/8 - 27 NPTF</td> <td> 12</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Cooler Line Fitting into Case (97- early 99)</td> <td> 1/4-18 NPSF</td> <td> 28</td> <td>
</td> </tr> <tr> <td> Cooler Line Fitting into Case (mid 99- 03)</td> <td>Feed 3/8-18 NPSF
Return 1/4-18 NPSF</td> <td>
</td> <td>
</td> </tr> <tr> <td> Cooler Line Fitting into Case ( 04+ )</td> <td> 9/16-18 UNF</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Accumulator Cover Bolts</td> <td> M6 X 1.0 X 28</td> <td>
</td> <td> 106</td> </tr> <tr> <td> 2-1 Manual Servo Cover Bolts</td> <td> M8 X 1.25 X 25</td> <td> 17</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Oil Pump Cover Retaining Bolt (97-mid 02) - 1</td> <td> M6 X 1.0 X 20</td> <td>
</td> <td> 70</td> </tr> <tr> <td> Oil Pump Bolts - 9</td> <td> M6 X 1.0 X 85</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Oil Pump Bolts - 2</td> <td> M6 X 1.0 X 95</td> <td> 11</td> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Valve Body Bolts - 3</td> <td> M6 X 1.0 X 65</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 3</td> <td> M6 X 1.0 X 60</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 1</td> <td> M6 X 1.0 X 30</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 2</td> <td> M6 X 1.0 X 45</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 3</td> <td> M6 X 1.0 X 55</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 1</td> <td> M6 X 1.0 X 95</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 2</td> <td> M6 X 1.0 X 20</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Valve Body Bolts - 1</td> <td> M6 X 1.0 X 85 </td> <td>
</td> <td> 106 </td> </tr> <tr> <td> Valve Body Bolts - 1</td> <td> M8 X 1.25 X 90</td> <td>
</td> <td> 18</td> </tr> <tr> <td>
</td> <td>
</td> <td>
</td> <td>
</td> </tr> <tr> <td> Case Cover / Channel Plate Bolt - Torx - 1</td> <td> M6 X 1.0 X 32</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Case Cover / Channel Plate Bolt - 3</td> <td> M6 X 1.0 X 30</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Case Cover / Channel Plate Bolt - 3</td> <td> M6 X 1.0 X 40</td> <td>
</td> <td> 106</td> </tr> <tr> <td> Case Cover / Channel Plate Bolt - 3</td> <td> M8 X 1.25 X 50</td> <td>
</td> <td> 18</td> </tr> <tr> <td> Detent Lever Spring Bolt</td> <td> M6 X 1.0 X 16</td> <td>
</td> <td> 106</td></tr></tbody></table>
Old May 3, 2013 | 1:04 AM
Brok's Avatar
Good friend of mine from another site posted me some photos of the check ***** location with sizes to help me out. If anyone could assist me on the torque specifications be nice.
Old May 4, 2013 | 2:52 PM
Brok's Avatar
Default Trasher or transgo shift kits for the 4T65E transmission are they worth it?
Has anyone owned or got one of these and how many miles and did they help fix the problems they promised? If so could you please post back to me mileage when you got it and how many mileage now and if it was worth it. For the small amount of money they ask for it I may consider buying it as I can put it in all my accumulators 1-2 2-3 3-4 and put in the extra goodies they have as well. I am just wondering if it is a good product to get or if it is a fail that you see down the years. Any reply or input is greatly appreciated.
itswrongway
Jun 16, 2015 10:36 PM
rdeyoe
Feb 2, 2015 10:07 PM
Chevrolet Forum News
May 18, 2013 1:50 PM
Brok
May 2, 2013 8:56 PM
