Platform: A-, G-, & W-body
98 Lumina LTZ brake light goes out
Old Jul 8, 2010 | 10:19 AM
mrytk421's Avatar
Default 98 Lumina LTZ brake light goes out
My wifes 98 Lumina's passenger side(right) brake light goes out when using the driver side(left) turn signal. I have been told this could be a grounding issue but i have no idea where to start looking. Any information would be appreciated.
Old Jul 8, 2010 | 8:29 PM
MDTAHOE's Avatar
Professional Mechanic
99% of the time this is a ground issue in the socket. Replace the socket, half of the time you can not see anything wrong with it.
Old Apr 19, 2011 | 9:25 PM
folkerson69's Avatar
try pulling back on the turn signal switch lever, there is a flaw in the turn signal switch of the lumina and monte carlo, my car did this also, i have a 98 monte and i had to pull back on the lever to get the brake lights to work.
Old Aug 16, 2011 | 12:11 AM
holiday112284's Avatar
sounds like a bad turn signal switch i had the same problem with mind replacing the turn signal switch fixed it.this is a common problem with the w-body vehicles.
02SS
Mar 1, 2015 5:45 PM
big-foot
Dec 8, 2012 12:43 AM
isrummell
Jul 8, 2012 5:09 PM
