Platform: A-, G-, & W-body
fuel problems
Old Aug 3, 2012 | 8:05 AM
tim_lemmy's Avatar
Default fuel problems
Hi guys,
I have a 1987 Monte Carlo SS that's been "upgraded" by someone in the past. It has a 350 TPI with a 700R4 transmission. The problem is that it won't run without spraying fuel into the throttle body. The fuel pump and fuel lines have been replaced. So here's the dilemma, is it the ECM? Or could there be another problem? If it's the ECM, what do I need to get it off of. Are there differences between the different 350 TPI's? Is it feasible to just convert back to carbureted? Do you have any other suggestions? Thanks in advance for any and all help.
Tim
Old Nov 4, 2013 | 9:23 PM
angelraue's Avatar
Replaced fuel pump relay switch is good I got a code 1516 or something like that on 03 chevet tahoe I'm not getting any fuel to the injector any ideas
Mom2ThreeACG
Traverse
Mar 12, 2018 6:20 PM
mwehrste
Dec 29, 2014 11:19 AM
hunter10220
May 18, 2011 8:37 PM
MrPuzzlez
Jan 4, 2009 12:02 AM
