Platform: A-, G-, & W-body
No compression trouble shooting
Old Jul 9, 2017 | 6:49 AM
  #31
kevinkpk's Avatar
Probably need to align the oil pump shaft with the distributor. Turn it upside down (distributor), there will be a (not sure anymore on late modle chevy) a pin that slots into the oil pump drive shaft. Take a screw driver in the intake where the distributor goes, and align the pump shaft to correspond with the distributor shaft.
Old Jul 9, 2017 | 8:48 AM
  #32
V12TT's Avatar
You was right but it was impossible for me to adjust the pump shaft with a screwdriver. This was mentioned on a few you tube video too but I can't seem to be able to place the screwdriver head on the pump shaft.
I went to O'reiily and spoke to a few guys. One guy knows a trick and I hope that it will help someone here:
1. Move the harmonics balancer off TDC until the distributor cap sits in the correct positionNo compression trouble shooting-photo305.jpg
2. Lock the distributor down.
3. Move the harmonics balancer to TDC.
4. Loosen up the distributor and move the camshaft to the final position.
I turned the key and it turned over!!!
The shaking issue was gone and all cylinders have good compression!
I appreciated all your helps & encouragements.
