Platform: A-, G-, & W-body
Starter Relay in Chevrolet Lumina 95
Old Feb 25, 2009 | 1:22 PM
Darkpikasso's Avatar
Default Starter Relay in Chevrolet Lumina 95
Hey guys..
Thanks for letting me in to the forum is a very cool forum...
Can anyone tell me where's located the Starter Relay in the Chevrolet Lumina 1995?
I'm trying to do a killswitch from there, well a think i can make it, anyone colud help in this matter too?
Thanks a lot for your responses...
Old Feb 25, 2009 | 9:48 PM
EvansBlue's Avatar
Thanks for the compliments on the forum. I take pride in knowing that I'm a part of making it what it is today.
You are not going to be able to kill the engine through the starter relay. You'll be able to prevent it starting.
You need to tap the primary ground for your ignition switch.
Old Feb 26, 2009 | 10:32 AM
Thanks for the response EvansBlue...
So, i well just prevent to starting the car, that's ok, now there's any diagram or cuircuit to know what to use and how to connect all the wires to car or how to do the install...
Thanks again.
Old Feb 26, 2009 | 11:26 AM
EvansBlue's Avatar
I don't have a wiring diagram for a lumina, but I'm sure someone on the site does.
Old Feb 26, 2009 | 2:05 PM
What dou you think about this one
Or can anyone tell me, how to do it? or claring me up a little bit the diagram...?
I think the diagram, show's how to make the killswitch, touching on one side the bolt or the contact and some harness to have ground in order to have current..
Thanks for your help..
Old Feb 26, 2009 | 2:38 PM
EvansBlue's Avatar
What are trying to do exactly? Do you want to make the engine cut off at the flick of a switch, or make it so you have to flip a switch to start the engine?
Old Feb 26, 2009 | 4:17 PM
not flick exactly...
Here in Mexico, we call it, "Cortacorriente de Tacto", it's a killswitch for the car, when you put it, you have to touch a spot, metal spot or screw and the harness of metal like the cigarrette lighter....when you touch the both point you power up the accesories and the electrical system for the car y crank it...
Thats what i'm trying to do...
Old Feb 26, 2009 | 9:16 PM
EvansBlue's Avatar
Oh ok. You need to wire it in series with the control leads of the starter relay.
Google Translate:
English>Spanish
Ingles>Espanol
Tienes que cambiar el cable en serie con el control del juez de salida conduce relé.
tracerbullet
Dec 6, 2012 2:49 PM
spencerdad2010
Aug 9, 2012 4:53 PM
nuguns
Jul 17, 2012 9:37 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
hueyg
Jan 28, 2009 7:05 PM
