car buying tips
Old Jun 8, 2010 | 2:09 AM
vimarsha's Avatar
Default car buying tips
1. Check how neat the car is in its external appearance. You must have a look at the car under bright sun so that* any uneven paint jobs can be easily identified. Incase you identify one, run your hand through the body line and you would defineatly find there is a difference in smoothnees. If the damage is huge, avoid such car.
** 2. Check the underbody of the car for any major scratches/damages. people generally make up the exteriors but there is not much they can do to coverup things under the car.
** 3. Check for the original stickers of the car in the engine area. You can see the natural wear and tear if the area is not quiet touched which is a good sign.
** 4. Ask if the service schedule has been maintained.
** 5. Make sure the tires, are in good condition. This could incurr sizeable cost incase they require replacement.
** 6. Like already mentioned, the lesser the car clocked on the ODO, better it is.
** 7. Check for the rubber beadings on the door.* Incase the car had a major collision, the impact can be easily see.
** 8. While take a test ride do not switch the music system On. Also roll the windows up for first few kilometers witout the AC or the Blower On. This will give you a clear sounds from the car's body and the engine. You mechanic can help you with the
srm51475
Jan 27, 2015 6:53 AM
aaronbleop
Jul 23, 2014 1:06 PM
604chevy
Mar 7, 2012 10:20 PM
sloop
Jan 4, 2012 9:13 PM
Crusader556
Apr 8, 2008 10:49 AM
