Paint, Body, & Interior Getting resprayed? Want to discuss body modifications? What about your carpeting and upholstery? This is the place for it!
Keeping tire lettering white
Old July 12th, 2007, 5:13 PM
EvansBlue's Avatar
Default Keeping tire lettering white
I recently ran across an article about keeping your white letters white so I'll share some of the content in paraphrase form.
Most tires, after a few years of age, start to fade or yellow. Tires that are used every day tend to pick up raod grime and look dingy and dirty. There are a few steps you can take to whiten them. So here are some tips about different things to use and what they do to the rubber.
-Whitening by a strong bleach will fade the black rubber on the rest of the tire, don't use it.
-**Degreasers (greased lightning, etc)work well but after many times of use it will start to dry rot the rubber because it is a chemical that works against petroleum.
-**Laquer thinner is by far the best at whitening, but it must be applied only to the letters themselves and without scrubbing.**[*]-Mineral spirits works with no majorside effects to the rubber.
-Bar soap is a good thing to use, but requires a lot of scrubbing.
-Tire bleach (Wesleys Blech-White, tire clean, etc) is great at cleaning the tire, but not whitening the letters if they are extremely filthy
-Shoe cleaner/glass cleaner or anything with mild amounts of ammonia work very well.
-Never use Varsol.
**Care should be taken around aluminum and alloy wheels and all painted rims.
Old November 18th, 2007, 6:32 PM
Default RE: Keeping tire lettering white
ORIGINAL: EuroGoldLS-Tire bleach (bleche white, tire clean, etc) is great at cleaning the tire, but not whitening the letters.
I've used Westley's Bleche-Wite for years and found it does very good at both cleaning the tires and white letters. But then I don't let them get that grungy.
Old November 19th, 2007, 4:31 PM
EvansBlue's Avatar
Neither do I, but I wash workvans too...
Old February 18th, 2008, 4:31 PM
ehhget's Avatar
i just use the papertowel i cleaned my windows with and it works great- little bit of window cleaner does a great job
Old March 2nd, 2008, 11:27 AM
#1SuburbanFan's Avatar
I know duplicolor makes a paint marker so you can paint your letters white, yellow, or red
Old March 2nd, 2008, 9:01 PM
EvansBlue's Avatar
You won't get good results from those. They make a mess if you are not careful.
Old March 3rd, 2008, 12:55 AM
Is it very permanent?
Old March 3rd, 2008, 11:05 AM
EvansBlue's Avatar
I used them on the old set of goodyears I had. The right rear had some curb scarring, so I went over it with the pen. It wroked really good, but it was splotchy and I put it on too thick in places, it ran when the water hit it and then stained the whole tire a grayish color. The lettering stayed white a long time though.
Old May 10th, 2009, 7:37 AM
Dave B's Avatar
I have always had my lettering snow white using Westley's Bleech White. It seems to work pretty good for me. Then I wipe the tire down with Mothers Back To Black because it seems so get the tire real black and not give it the ghetto supershine look.
Just my opinion.
I am not a professional detailer and there might be something better out there.
Tax as
Silverado & Fullsize Pick-ups
November 27th, 2013 11:38 PM
Tfriend
October 25th, 2013 7:46 PM
Woody!
December 7th, 2010 4:05 PM
BigDrew
July 31st, 2008 9:13 PM
Wirwin90
February 28th, 2008 9:09 PM
Quick Reply: Keeping tire lettering white
