S-10 & Blazer 1982-2005
03 S-10 instrument & radio lights blank
Old Jul 2, 2008 | 11:33 PM
I_Tinker's Avatar
Default 03 S-10 instrument & radio lights blank
Have an 03 S-10 4-cyl, auto. Runs fine, but radio display and speedometer/gauges blank when running through tunnel or after dark. Odometer remains bright. Everything is brightduring daylight. Any suggestions?? Thanks!
Old Jul 3, 2008 | 4:51 PM
EvansBlue's Avatar
Default RE: 03 S-10 instrument & radio lights blank
There is a dimmer next to the headlight switch. Roll it upward until the interior lights turn on, thenbringit back one notch. That will put the gauges at full brightness. If that doesn't work, let me know, we'll go to the next diagnosis.[/align][/align]When theAutomatic Headlightsturn on (Daytime running lights turn off), the brightness of the dash lights becomeadjustable withthe dimmerwheelexcept for the gear selector and the odometer. [/align][/align]
Old Jul 3, 2008 | 8:17 PM
I_Tinker's Avatar
That was it. Can't believe I didn't check the obvious after the neighbor borrowed my truck the other day. Went right into the troubleshooting mind-set because the radio's sound was also cutting out intermittently on every station when I got it back. I assumed theissues were linked and started with the constant symptoms first. Thanks for making me re-learn rule one of troubleshooting and check all operator settings. I'm embarrassed, but appreciate your patience. Thanks again!
boho115
Jul 10, 2013 7:15 PM
Sasr24
Mar 15, 2013 4:19 PM
crhoads
Feb 24, 2012 1:27 PM
RandyW
Oct 21, 2011 9:53 AM
stchman
Jan 4, 2009 12:35 PM
