S-10 & Blazer 1982-2005
1996 gmc jimmy 4.3 vortec misfire
Old Oct 17, 2018 | 10:08 AM
Twell47933's Avatar
Default 1996 gmc jimmy 4.3 vortec misfire
New plugs wires and cap and rotor cat is gutted out to. It has a misfire between 2-3k rpm under a load. If I down shift to second and drive at 3000-3500 rpm the sputtering gets worse and gets to where it’s pops out the exhaust. Codes I’m getting are p0420 and p1441
Old Oct 17, 2018 | 10:45 AM
geo1's Avatar
How were the old plugs?
Old Oct 17, 2018 | 11:43 AM
Twell47933's Avatar
they looked normal to me light brown ish kinda color
Old Oct 17, 2018 | 2:38 PM
geo1's Avatar
The "popping out exhaust"makes me think , ignition module,did that and 1441 show up at same time?
Old Oct 17, 2018 | 2:49 PM
Twell47933's Avatar
1441 came on yesterday its been acting up for quite awhile it’s been parked for about a month been driving it all week I’m waiting for it to give me a misfire code or something I can get some info off of
Old Oct 17, 2018 | 3:43 PM
geo1's Avatar
Have you cleaned the MAF?and how old is fuel filter, trying to think of,what's making a lean condition,you could also unplug cts,make it go rich,see if drivability improves
Old Oct 17, 2018 | 7:45 PM
Twell47933's Avatar
cleaned maf late last year and fuel pump and filter were done in 2015
Old Oct 17, 2018 | 8:52 PM
geo1's Avatar
Change the filter,going on 4 years,and I would disconnect cts for a test drive
Old Oct 18, 2018 | 11:44 AM
Twell47933's Avatar
new update it’s misfiring pretty bad still but it seems like only in the mornings in the afternoon it’s fine. Also when it’s missing out it will kick out or overdrive going down the road
Old Oct 18, 2018 | 11:57 AM
geo1's Avatar
What grade plug wires did you install?sounds like you have stray spark,I would use a spray bottle with water in it,slowly spray plug wires when it's behaving,try to get it to misfire,or take a peak under hood with limited light,look for arcing at plug wires
