S-10 & Blazer 1982-2005
93 s10 4.3 hard start and stalling. Fuel injector issue??
Old Apr 14, 2015 | 10:34 AM
slicedpi's Avatar
Default 93 s10 4.3 hard start and stalling. Fuel injector issue??
Hello everyone, new to the forums. I brought a 93 s10 back from the dead a couple years ago when I bought it from a friend and dropped a rebuilt motor into it. A few months after I bought it, it had an issue with one of the fuel injectors that would intermittently stop spraying. It would buck, and kick, and stutter, finally getting back to normal. I took off the TBI, took it apart cleaned it, replaced all the gaskets, and rebuilt it. I replaced all the premolded vacuum lines with hose, new pcv valve, and new connectors for the IAC valve and MAP sensor because the old connectors were corroded. I put new injectors in, but it would stall shortly after starting, so I put the old injectors back in.
Now to today. It had been running okay for a few weeks, it would have a rough, low idle but I could drive it. Then a few days ago it was just cranking until I gave it gas, then it would start but immediately stall. I changed the MAP sensor and IAC valve and it ran great for two days (after a few minutes of high idle right after changing those parts). Now it is doing the hard start and stalling again.
I looked at the injectors as it was doing this, and they are definitely dripping. And they continue to drip for a couple seconds after it stalls. Is this an issue with the injectors? Or could it be something else, maybe with the throttle body? What could be causing the extended cranking?
I made a video to better illustrate the issue:
Thanks in advance for any help!
tl;dr
93 vortec v6 extended cranking (hard start) and stalls immediately after turning over. Fuel injectors are dripping. Replaced MAP sensor, IAC valve, connectors, pcv valve, vacuum hoses, and cleaned/rebuilt the TBI. Where do I look from here? New injectors?
Old Jun 12, 2023 | 8:56 PM
93s10man's Avatar
I made a video to better illustrate the issue: 93 Chevy S10 v6 hard start and stalling issues. - YouTube
tl;dr
It is your fuel pressure regulator. Would not hurt to xhange your tps sensor also.
Old Jun 13, 2023 | 12:37 AM
oilcanhenry's Avatar
tl;dr
What is your fuel pressure? should be about 16 PSI. If you can find an OBD I scan-tool, I'd run that and see if anything shows up. After that, I'd reset the entire system.
Off topic but your Schrader valve cap is missing on your A/C receiver-dyer Keeps the dust out, and very cheap too.
Old Jun 13, 2023 | 9:45 AM
Rednucleus's Avatar
Ummm, 8 year old thread!!
epagidas
Dec 9, 2023 8:58 PM
SpencerSuburban
Mar 26, 2019 6:19 PM
Vlvman
Jun 7, 2011 6:24 AM
geozeke
Oct 19, 2009 3:17 PM
ptrkptz
Aug 5, 2009 11:42 PM
