S-10 & Blazer 1982-2005
blower fan failure 96S10
Old Nov 21, 2006 | 7:40 AM
redtop's Avatar
Default blower fan failure 96S10
the blower fan does not work at any speed.
initially, i've checked fuses, which are OK. what's the next step? thanks in advance for your consideration...
redtop
Old Nov 21, 2006 | 12:20 PM
golfer's Avatar
Default RE: blower fan failure 96S10
ORIGINAL: redtop
redtop
If your 100% sure of the fuses then disconnect the connector to the blower and jumper 12volts to it and see if it works.
If this works then start tracing back toward the switch for voltage.
Old Nov 25, 2006 | 12:42 AM
70mopar's Avatar
redtop, if u haven't fixed the problem yet here r some suggestions 2 check. tap the relay that is mounted 2 the outside of the heater box with a screw driver (or something like it), if the relay is acting up, the blower should come on (put the switch in a postion so u'll hear it start up). if this doesn't do anything, try checking the speed controller resistor (the 3-prong part sticking out of the top of the heater box). since u said the fan does't work @ any speed, i would check the relay first. good luck.
beaseac
Dec 22, 2019 11:54 AM
wildstrings
Jun 19, 2014 2:10 PM
jmpretty
Uplander
May 1, 2014 1:50 PM
bradyra1
Apr 20, 2007 11:00 AM
