brake lights stay on
I own a2000 s-10 ls. I have recently noticed that the brake lights will stay on even when i turn off the ignition. This only applies to the 2 main tail lights. The 3rd light above the cab works fine though. turn signals and reverse lights also are fine. As soon as i touch the brake pedal, the brake lights come on then stay on. I have to remove the fuse to get them to shut off. Has anyone else had this problem? Is it an expensive fix?
Had the same exact problem on my '98. It is the headlight relay under the hood in the fuse block. To check it, just switch it out with another in the block. Good luck.
there is a little rubber piece on the peddle that pushes the brake light switch in and if it gets old it pops out and then the brake light switch has nothing to press again so you could check that.
andrewpowell
May 27th, 2022 3:29 AM
cowboys
December 18th, 2006 12:28 AM
