S-10 & Blazer 1982-2005
brake lights stay on
Old Apr 18, 2008 | 7:44 AM
blues10's Avatar
Default brake lights stay on
I own a2000 s-10 ls. I have recently noticed that the brake lights will stay on even when i turn off the ignition. This only applies to the 2 main tail lights. The 3rd light above the cab works fine though. turn signals and reverse lights also are fine. As soon as i touch the brake pedal, the brake lights come on then stay on. I have to remove the fuse to get them to shut off. Has anyone else had this problem? Is it an expensive fix?
Old May 5, 2008 | 11:12 PM
golfer's Avatar
Default RE: brake lights stay on
Check the switch at the brake pedal.
Old May 6, 2008 | 6:22 PM
shawnvw's Avatar
Banned
Try wiggling the turn signal switch a bit, also, make sure the Hazard switch isn't partially depressed.
Old Jun 19, 2008 | 9:45 PM
Koach21's Avatar
Had the same exact problem on my '98. It is the headlight relay under the hood in the fuse block. To check it, just switch it out with another in the block. Good luck.
Old Oct 23, 2009 | 5:32 PM
Pacci1eR's Avatar
there is a little rubber piece on the peddle that pushes the brake light switch in and if it gets old it pops out and then the brake light switch has nothing to press again so you could check that.
andrewpowell
May 27, 2022 3:29 AM
acydtryp
Sep 9, 2015 8:52 PM
Bmoorecop
Jul 12, 2014 3:54 PM
lifemedic6203
Mar 8, 2010 1:34 PM
cowboys
Dec 18, 2006 12:28 AM
