S-10 & Blazer 1982-2005
Brake lights stuck on, please Help
Old Sep 17, 2010 | 5:26 PM
chevman711's Avatar
Unhappy Brake lights stuck on, please Help
On occasion after I park my truck or when I’m returning to my vehicle I will notice my brake lights are on. If I start it up and press the brake pedal a few times they go off (and appear to operate normally). What would cause this? Is there anything I can do to troubleshoot this problem?
Recently I installed an Amp and a subwoofer. I did all the wiring for the project except splicing the hi-lo converter to the stock deck (that I had done at Best Buy). I don’t want to bother the good folks at Best Buy until I have investigated this problem…
thank you
Old Sep 17, 2010 | 10:33 PM
97-SilveradoMan's Avatar
It sounds like its either a short in the wiring or your fuse box is acting up. But since you said you were doing wiring i would check and recheck your wiring job. you might have accidently knicked your brake light wires
Old Sep 17, 2010 | 11:00 PM
MDTAHOE's Avatar
Professional Mechanic
Look into the brake light switch. Look down by the pedal and wiggle the switch you will most likely find the problem.
Old Sep 18, 2010 | 9:52 PM
chevman711's Avatar
Well, I poked around near the pedal. Moved around the wire harness etc. The brake light switch appears to be enclosed in a white plastic module.
Heres a few wiring diagrams of what I installed http://www.cardomain.com/ride/3359737/2
My Relay and Inverter tie into an existing ground in the passenger footwell (I pulled a bolt that was used as a ground and added my ground to it) I'm a little concerned that may be the problem...
I'm going to spend some time in the shop manual and see what those grounds do.
Thanks again for your replies
Old Sep 20, 2010 | 1:41 PM
chevman711's Avatar
Edit:
The grounds in question are too far foreword and appear to be part of the dashboard wireharness.
I found my brake lights on, this time I pumped the brakes and had a friend watch the lights. After a dozen or so brakes the lights would operate normally. As I continued to pump the brakes they would get stuck on then after a few cycles operate normally etc. My third brake light operated normally throughout the test.
Can I rule out the brake switch? Or is it still suspect?
screetcher
Mar 5, 2015 5:55 PM
MattOrange
Sep 3, 2014 8:34 AM
aaaaa
Dec 5, 2011 7:52 PM
skdevore
Aug 26, 2009 10:18 PM
waterski
Jul 21, 2008 11:44 PM
