S-10 & Blazer 1982-2005
Cranks but wont start
Old Feb 10, 2008 | 11:09 PM
  #21
blazerman's Avatar
Default RE: Cranks but wont start
For cold starts, check your battery first. It could be just discharged. Also if you have too heavy of an oil it will hard start in the cold. Another thing I figured out with a honda, was the Engine Coolant Sensor was bad, causing hard starting in the mourning because it controlled the computer before the oxygen sensors were hot enough to work.
Old Feb 11, 2008 | 1:28 PM
  #22
74chevy4life's Avatar
Well the first thing i checked was the battery and the oil is the right wait 5w30 and i replaced the engine coolante temp sensor
Old Feb 13, 2008 | 10:29 PM
  #23
00blkjimmy's Avatar
I have a 2000 jimmy with the 4.3 and i had a problem with it cranking but not starting. Chased the problem all over butfinally my mechanic told mefrom experience with theses trucks that an ignition sensor in the steering column was shot. it was a fuel cut off apearently for the security systems in these trucks. it didnt seem temp related but didnt really notice. once it was replaced i havent had a starting problem since
Old Feb 14, 2008 | 10:13 AM
  #24
Thanks for the info 00blkjimmy if have been doing a lot of research and that ingintion switch seems to be the only thing let that i havent changed that could be the problem
lonewolfbanhmi
Sep 26, 2012 12:50 PM
evilone
Jun 5, 2012 6:20 AM
Slugga
Sep 24, 2010 9:41 PM
kenehsr
Sep 5, 2010 5:08 PM
mike78olds
Sep 17, 2007 9:33 AM
