S-10 & Blazer 1982-2005
ignition problems
Old Aug 18, 2021 | 2:46 PM
jdbates's Avatar
Default ignition problems
Good afternoon. I have a 1995 s10 4.3 TBI and I'm not getting voltage to fuse #10 that is hot with ignition on 20amp ECM ignition circuit. Same with fuse #4 also a hot with ignition on 20 amp for the gauges. I believe voltage is good on all other fuses. I'm replacing the ignition switch today but I have a feeling that it's not going to help with my problem. I've not yet found a wiring diagram that shows the wire that feeds these two fuses. Thanks for any input that anyone might have on this issue.
Old Aug 18, 2021 | 3:37 PM
hanky's Avatar
Hi jd,
What is usually the set up,
Power is present at the fuse panel to a row of terminal plugs that once a fuse is inserted that allows power to the system /circuit the fuse protects.
Old Aug 18, 2021 | 4:21 PM
jdbates's Avatar
Thank you very much. I have the fuse block/panel pulled out now checking it. Have a good evening and again thank you.
Old Aug 18, 2021 | 8:22 PM
jdbates's Avatar
I replaced the switch and that fixed it. Thanks for the help.
jameszr2
Oct 19, 2018 10:54 AM
gsage2004
S10 & Blazer DIY and Useful Threads
Jul 14, 2018 6:51 PM
matthewmcw
Jan 11, 2013 4:55 PM
two blazers twice the headache
Apr 6, 2011 11:27 AM
theory6
Nova & Chevy II
Apr 16, 2007 7:47 PM
