S-10 & Blazer 1982-2005
Motor change wiring help?
Old Feb 19, 2007 | 2:57 AM
zuber7's Avatar
Default Motor change wiring help?
I have a wrecked 1998 s10 with 4clylinder I am putting in a 1987 s10 pickup. They are both 2wd. I am wanting to know if someone could tell me or tell me where to go to find out the wiring info I will need to know.
Old Feb 19, 2007 | 1:37 PM
shnormo's Avatar
Default RE: Motor change wiring help?
Just take the old PCM out and follow all the leads from it. Those are all the wires you will need.
Old Feb 21, 2007 | 3:04 AM
kcb37's Avatar
shnormo is right. But that is your engine wiring. I would swap the tranny too. All your interior lights should be on another harness. If you cut the old one out of the 87 just make sure you don't hit any of those wires. You may want to see if you can swap the gas tanks too. The 98 being fuel injected will most likely need more fuel pressure.
jwsimiskey
Oct 21, 2012 10:18 PM
spartanzz
Aug 6, 2012 3:42 PM
DeHartShadow
Mar 28, 2010 10:10 PM
GMontag451
Sep 30, 2008 6:01 PM
digdug
Feb 4, 2007 3:08 PM
