S-10 & Blazer 1982-2005
Need air bag help
Old Aug 9, 2012 | 5:49 PM
mcstein's Avatar
Default Need air bag help
Here's my issue. I have an airbag light and my horn doesn't work. I'm pretty sure that my cruise control doesn't work but I haven't tried it in a long time. After research I found it was most likely the airbag clock spring. So I went to the local pull-a-part and got one to replace it with. It didn't fix anything so I figured it was bad too. Now I just replaced that one with a new clock spring from the store and it too didn't change a thing. What else could it be? Neither Chilton or Haynes help at all as far as trouble shooting the airbag system go. Any ideas?
BTW it's a 1996 s-10, ext cab, v6 4.3L (x), 5 spd, 160k.
Thanks
Old Aug 9, 2012 | 8:57 PM
MDTAHOE's Avatar
Professional Mechanic
You need to have the air bag computer scanned for codes then go from there.
Old Aug 10, 2012 | 4:46 AM
mcstein's Avatar
Where can I do that? At the shop? The scanner at the parts store won't scan for airbag codes.
Foxxtrot
May 15, 2015 1:03 PM
J.R
Jan 6, 2015 8:41 PM
chevvirgin
May 7, 2012 4:30 AM
scott_mckinney
Jun 24, 2007 2:48 PM
MarineSSgt
May 14, 2007 3:01 PM
