S-10 & Blazer 1982-2005
neutral safety switch
Old May 15th, 2014 | 7:59 PM
S10forever's Avatar
Default neutral safety switch
HI,Has anyone had any experience with the neutral safety switch that is supposed to be under the gear shift in a s10 Sonoma 5 spd.
I heard about this today and may be why we are experiencing with shutting down when ever it wants to,its supposed to be a mildly difficult fix,thank you
Old May 15th, 2014 | 10:21 PM
S10forever's Avatar
Well we took gear shift lever out and there was no wiring under it so that's one less
problem to worry about I cheated and hooked up DDV to wires coming to pump and showed I had 12.87 volts in incoming wire.
Next will pull pump and see if wiring on it is bad.
Old May 16th, 2014 | 1:05 AM
the neutral safety switch is part of the starting circuit. it will only inhibit the starter from cranking. it will not cause an already running truck to intermittently shut down as you have described.
Old March 15th, 2017 | 10:45 AM
Cortez34's Avatar
Default No power
Need help I replaced me starter thinking it was the starter but it turns out I am not getting any power to the small wire going to the starter I replaced the ignition switch the electrical part not the key part and nothing my truck is a1981 chevy short bed c10 and I was checking the neutral safety switch and the only power I am getting down there is from the yellow wire not the purple wire when I turn the key
Old March 16th, 2017 | 9:20 AM
bypass or jumper the switch
or
disconnect the switch connector and ohm check the switch. open with clutch released, closed with clutch engaged.
mdl2424
August 28th, 2015 1:26 PM
Randito
Chevelle & El Camino
July 7th, 2013 5:11 PM
Drizink43
October 11th, 2012 3:38 PM
91blazer91
February 24th, 2012 11:00 AM
P20stepvan
December 22nd, 2011 6:01 AM
Quick Reply: neutral safety switch
