S-10 & Blazer 1982-2005
neutral safety switch
Old May 15, 2014 | 6:59 PM
S10forever's Avatar
Default neutral safety switch
HI,Has anyone had any experience with the neutral safety switch that is supposed to be under the gear shift in a s10 Sonoma 5 spd.
I heard about this today and may be why we are experiencing with shutting down when ever it wants to,its supposed to be a mildly difficult fix,thank you
Old May 15, 2014 | 9:21 PM
S10forever's Avatar
Well we took gear shift lever out and there was no wiring under it so that's one less
problem to worry about I cheated and hooked up DDV to wires coming to pump and showed I had 12.87 volts in incoming wire.
Next will pull pump and see if wiring on it is bad.
Old May 16, 2014 | 12:05 AM
the neutral safety switch is part of the starting circuit. it will only inhibit the starter from cranking. it will not cause an already running truck to intermittently shut down as you have described.
Old Mar 15, 2017 | 9:45 AM
Cortez34's Avatar
Default No power
Need help I replaced me starter thinking it was the starter but it turns out I am not getting any power to the small wire going to the starter I replaced the ignition switch the electrical part not the key part and nothing my truck is a1981 chevy short bed c10 and I was checking the neutral safety switch and the only power I am getting down there is from the yellow wire not the purple wire when I turn the key
Old Mar 16, 2017 | 8:20 AM
bypass or jumper the switch
or
disconnect the switch connector and ohm check the switch. open with clutch released, closed with clutch engaged.
mdl2424
Aug 28, 2015 12:26 PM
Randito
Chevelle & El Camino
Jul 7, 2013 4:11 PM
Drizink43
Oct 11, 2012 2:38 PM
91blazer91
Feb 24, 2012 10:00 AM
P20stepvan
Dec 22, 2011 5:01 AM
