S-10 & Blazer 1982-2005
S10 not starting any suggestions?
Old Jul 10, 2023 | 7:45 PM
Mcalnan711's Avatar
Default S10 not starting any suggestions?
My 97 S10 with 75k miles started running rough….hesitating…bucking…in the last 3 months I replaced
1) plugs and wires
2) fuel filter
3) cap and rotor
4) Mass airflow sensor
5) Coil
it kept behaving badly and stalled a few times and then stalled and wouldn’t start…it was kicking off code 0300 (thanks that helped a lot). LOL
So I replaced
6) fuel pump
I’m Getting 60-65 PSI fuel pressure from the new pump even jumped the pump to make sure it was getting fuel.
i haven't replaced the ignition module yet or the ECM.
Any suggestions? Thanks!
most of the stuff was preventive maintenance or due ~75k miles and I’ve only spent about $200 and a bunch of swearing…
I swapped the 3 modules in the glovebox around too to see it there was a bad one!
Old Jul 11, 2023 | 9:09 PM
oilcanhenry's Avatar
1) plugs and wires
2) fuel filter
3) cap and rotor
5) Coil
So I replaced
6) fuel pump
Likely the ignition module yet or the ECM like you mentioned.
Old Jul 16, 2023 | 3:05 PM
Mcalnan711's Avatar
okay replaced ignition module and it starts, but any pressing of the accelerator and ITS ROUGH!!
What next? ECM or bad injectors?
fuel pressure is 55psi+
thanks
Old Jul 16, 2023 | 8:16 PM
thanks
I'd go with the injectors having issues, if it starts.
Old Oct 16, 2023 | 5:42 PM
Mcalnan711's Avatar
Default Distributor Rotor
1) plugs and wires
2) fuel filter
3) cap and rotor
5) Coil
So I replaced
6) fuel pump
Ugh…after all this, I finally figured out the rotor was bad!
I bought an AC Delco Cap but the rotor was someone else!
a couple pals have told me the 90’s GM trucks do not like aftermarket fixes for the electrical
system!
lesson learned
Mggoelz
Jul 29, 2022 6:22 PM
RickPatten
Apr 9, 2014 8:35 PM
gbenn1970
Mar 30, 2014 12:34 PM
wsanders
Jan 30, 2014 3:54 PM
dabruguy
Jun 17, 2011 3:02 PM
