S-10 & Blazer 1982-2005
Thermostat problems
Old Oct 16, 2019 | 8:47 AM
Craftsman962's Avatar
Default Thermostat problems
Hello
My thermostat is fluctuating between 105 an 210 an finally stays on 105 an i am having to add coolant every now an then can't find no leaks
Old Oct 16, 2019 | 9:56 AM
Irish_alley's Avatar
I'm here for the party
the fluctuation is prop because of low coolant. have you had the coolant tested for exhaust gasses?
Old Oct 16, 2019 | 10:04 AM
I have no coolant coming out exhaust it's clean coolant is going some where water pump is clean dipstick is clean too.she don't try torun hot.
Old Oct 16, 2019 | 10:24 AM
U think i should change out the water pump to b safe an thermostat too.
Old Oct 16, 2019 | 10:54 AM
MiragePilot's Avatar
What year is your Express, and how many miles are on it?
Old Oct 16, 2019 | 10:58 AM
96 chevy S-10 auto 4.3 v-6 177.000
Old Oct 16, 2019 | 1:46 PM
moved your post to the appropriate spot. well it has to be leaking somewhere, park over a dry spot/clean area (if you cant find one put a piece of cardboard under the truck and let it idle to see if leaks any
Old Oct 16, 2019 | 1:59 PM
Ok thx for the info
Old Oct 17, 2019 | 11:51 AM
[QUOTE=Irish_alley;436518]moved your post to the appropriate spot. well it has to be leaking somewhere, park over a dry spot/clean area (if you cant find one put a piece of cardboard under the truck and let it idl
I did the cardboard over night trick no leaks nowhere ithis s getting frustrating she's not running hot not even trying to wonder if I should try running some sealant through my system an see what happens
Old Oct 17, 2019 | 11:54 AM
[QUOTE=Craftsman962;436590]
When I do have to add to my radiator it's not even half a, jug of coolant
