S-10 & Blazer 1982-2005
Truck simply shut off
Old Dec 18, 2012 | 9:10 AM
jrose1's Avatar
Default Truck simply shut off
93 S10 fired up fine, got down the street to the light and simply shut off. I have no dash lights, dome, headlights or underhood lights. Radio works and truck turns over strongly but won't catch. When sun comes up I will go through fuses. Any thoughts?<!-- google_ad_section_end -->
Old Dec 18, 2012 | 10:05 PM
go-part's Avatar
Former Sponsor
Well good thing is it doesn't sound like an electrical problem..
So start with checking the spark plugs and your injectors.
Make sure the battery connectors are clean and fully seated.
Check your wires and your distributor for ANY thing that is unusual.
Hopefully this is a simple fix.. good luck
Old Dec 20, 2012 | 3:53 AM
jrose1's Avatar
Default turns out...
...there's a positive wire that comes directly from the starter up to the cab. It runs very near tot he exhaust manifold and finally melted through. It carries all the juice up from the battery. A quick fix once you find it.
chevy350ga
Jun 21, 2015 3:45 PM
nherweck
Nov 3, 2011 8:36 AM
mike7792
Feb 26, 2007 3:34 AM
hexman512
Dec 29, 2006 10:23 PM
