S-10 & Blazer 1982-2005
Truck won't start
Old Apr 18, 2017 | 4:23 PM
Mous's Avatar
Default Truck won't start
Hi: I have a '94 S-10. Turn the key: a click that might be the solenoid, but the dash turns off & the door beeper stops. remove the key, wait awhile and it will do it again. turn the key immediately and nothing happens. suggestions?
Old Apr 19, 2017 | 9:29 AM
Check your battery and battery cables.
Old Apr 19, 2017 | 2:03 PM
Mous's Avatar
Thanks, that was part of it. Now the dash lights stay on but it still doesn't turn over. It's been sitting for 2 yrs on the coast, probably corrosion on electrical terminals. What's the easiest way to jump the starter?
Old Apr 19, 2017 | 2:31 PM
If your battery cables are corrosion free at both ends with tight connections then just jump it the normal way. You might have to connect the jumper cables and then let the car you are jumping from run a few minutes to charge up your battery some. you might have to buy a new battery.
Old Apr 19, 2017 | 3:36 PM
Mous's Avatar
The battery is good. Problem is I can't see or touch the starter connections, I thought there might be a simple way that I'm missing. I'm attempting to remove the ignition switch but will have to fake the special tool it takes to remove the lock plate under the steering wheel (haven't done that yet). It's all probably designed that way to keep thieves out but it keeps everyone else out too.
Old Aug 4, 2017 | 1:47 AM
Mous's Avatar
I got the starter to jump by inserting through the wheel well, an insulated coat hanger wire w/ a hook on the end that clips around the ignition connection on the starter. Then ran a wire over to the battery.
Coryay113
Aug 3, 2016 7:52 PM
gec
Feb 4, 2014 11:37 AM
sugardaddy1027
Dec 30, 2013 9:46 PM
kgetch
Nov 1, 2013 8:55 AM
m3the1
Aug 15, 2012 3:59 PM
