wont start
Old Oct 24, 2007 | 12:30 PM
gec's Avatar
gec
Default wont start
02 chev silverado turn key on fuel pump starts but when you turn the key the lights on the dash and radio go out, wont turn over.relay cliks in fuse panel but starter wont turn pls help
Old Oct 24, 2007 | 12:34 PM
gec's Avatar
gec
Default RE: wont start
This truck has done this 3 times before but has allways started after leaving it for awile, tried going through the search but can't find anyone with the same prob.
Old Oct 24, 2007 | 1:02 PM
MalibuMaxxSS's Avatar
if its clicking the batter/altenator is prollytoast, it takes way more juice to start it then it does to keep it running, the lights dimming is the truck draining whats left for life in your battery, my guess is the battery just wont take a charge anymore, and before when it did it, the battery was on the outs, but the Alt kept getting some juice to it, but now its finally dead
could be the Alt not charging anymore either and you finally ran your battery down.....the truck will run for a bit even if the alt is nor charging it, but it will eventually go...when you turn the key to on where is your battery guage reading....
Old Oct 24, 2007 | 1:07 PM
gec's Avatar
gec
Thats the thing...truck lights are bright and will not take a boost...possible security prob?
P.s. thanks for the reply!
Old Oct 24, 2007 | 1:21 PM
gec's Avatar
gec
This is becoming a dire emergency here...Its my neighbors truck (I have a 94...much easier ta fix!) He has no internet, we,ve checked the battery, starter wires etc. I wish I had a tech II handy. The truck has done this before and makes me think it could be security related. We will just have to sit here and drink my beer until it starts but by then we won't be able to go anywhere :-)
Old Oct 24, 2007 | 2:47 PM
gec's Avatar
gec
TY for the help Malibumax, I checked the battery and alt with a meter and both were good...got the owner to roll it ahead and slam it into park...Truck started!...I asked him to drop the starter and clean up the connections and hopefully the prob is fixed.
Old Oct 24, 2007 | 5:00 PM
could be a dead spot on the starter, and it wont turn and sucking all your power, let me know
Old Oct 24, 2007 | 9:45 PM
RonH's Avatar
ORIGINAL: gec
This sounds very much like the battery connections are either dirty or loose. They can look good, but still fail. There is enough current passing to power the dash and fuel pump, but not enough to power the starter.
Take the battery terminals (especially the positive) and inspect and clean them. Then reinstall them and be sure to get them good and tight. This will probably fix the problem.
Old Feb 4, 2014 | 11:37 AM
yotekillr's Avatar
My truck is doing the exact same thing. Ever figure this out?
Tootallmech
Aug 7, 2023 11:49 AM
sleepingciv
Jul 25, 2020 1:03 PM
bracca
Jul 12, 2009 6:14 PM
wildboy74ss
Apr 1, 2009 5:10 PM
