Notices
Sponsored by: DashLynx
6 lug 15" toyota rims on a 6 lug chevy
Old February 28th, 2010, 11:07 PM
gotstylez's Avatar
Default 6 lug 15" toyota rims on a 6 lug chevy
can a 15" rim that is 6 lug fit on a 6 lug chevy? right now i have 16" rims does the 1 inch matter? im thinking its bigger to fit over the caliber.. but does anybody i know?
" hopefully i wont get a sticky throttle i already dont have any breaks" HAHAHA had to say that
Old February 28th, 2010, 11:40 PM
992door's Avatar
i am pretty sure 15s will fit
Old March 1st, 2010, 12:30 AM
gotstylez's Avatar
taht would be awesome if they did! they got a set of 25" tires thay almost remind me of the tires u have 992door.. but the lugs on the outside of the tire are a little more smaller and more evened out.. or spaced out.. ..if it helps its a 84(or 82) yota and my truck is a 95
Old March 1st, 2010, 10:45 AM
julosibia's Avatar
http://rimhelp.com/searchrecords.php...rt=3&sort_type=
use the search in here. or look by bolt pattern. very helpfull. too bad i have 5 lug. having a hard time getting nice rims. got two stock, and three ss on mine right now.
Old March 1st, 2010, 10:49 AM
maxxman04's Avatar
i'm pretty sure most 15" will fit around the brakes fine. i think it's just the backspace/offset that might come into play
Old March 1st, 2010, 12:01 PM
ajhgoodwrench3's Avatar
Default rims
you are in luck, because i have a set of 15 inch toyota rims on my 2000 silverado, if you have drum brakes you wont have a problem, but if you have disk in the rear you will have to grind a little bit off your caliper, and they will fit great, i also have a pretty good ofset on my rims too, but i believe the older body style has smaller front and rear brakes than mine so you should be all set.
B.T.W. it aint done right unless its modified
Old March 1st, 2010, 12:24 PM
gotstylez's Avatar
nice site.. i had to go up to a 90s fourrunenr to even get the bolt pattern.. does anybody know if the 84 is the same as a 90? becuase if it is.. im in luck and i got me some 35s for my truck
Old March 1st, 2010, 12:35 PM
gotstylez's Avatar
[quote=gotstylez;133408]heres what i got IF the 90 and 82 is the same.....my chevy is 6x5.50in - 6x139.7mm and the offset is Low/Med
4runner is is 6x5.50in - 6x139.7mm and the offset is Medium
edit: it says wheel offset is 10-25mm on my chevy and on the yota it says 15-25.....whatever that means.. lol
chevyman323
July 16th, 2010 11:56 AM
jrsavoie
July 15th, 2010 9:55 PM
97RedBull
April 20th, 2010 7:53 AM
mike688
Uplander
January 25th, 2010 12:16 PM
texas patriot
October 17th, 2007 1:07 AM
Quick Reply: 6 lug 15" toyota rims on a 6 lug chevy
