Notices
Sponsored by: DashLynx
Bright Box!!
Old March 18th, 2008, 10:36 AM
FredChevy24's Avatar
Default Bright Box!!
I have a 1998 Silverado with a HIDkit forthe low beams (6000k). I am palnning on getting the HID kit for the high beams, but only if i can the low bems to say on when i turn on the high beams. So this brings me to the Bright Box; I heard about it and did some research, but i have a few questions. I heard you can save $90 and just use the diode trick? Can i do the diode trick with the stock harness or do i need to upgrade it? Or would should i just buy the bright box? But will the bright box work if i have a HID kit for the high and low beams?
Any help with this would be awsome!
Old March 18th, 2008, 12:36 PM
TransAm Man's Avatar
Default RE: Bright Box!!
You might need to get a new kit with high beams and low beams. http://www.brightheadlights-hid.com/
Old March 18th, 2008, 6:52 PM
But since i have already spent $150 on a HID kit for the low beams i dont really want to spend money on something i already have. Im wondering if I upgrade the wiring harness i can use the diode trick? Then buy the high beamHID kit so that all of my lights will match.
Old March 18th, 2008, 8:20 PM
Um, if you know how to do it and your willing dig into your wiring harness, go for it. I've done things like that on Hondas and Nissans so I suppose it won't be that painstaking. It's too bad you didn't get the high and low beam kit though.
Old March 19th, 2008, 10:09 AM
yea i know i should have got them both. but he said the kit would come with a seperate ballast for each light bulb so i figured i would just buy the low beam, i thought thats all i needed. But now i want the high beam kit since i heard about the bright box.
Old March 19th, 2008, 4:05 PM
Good luck with it...
Old March 20th, 2008, 8:00 PM
fireman526's Avatar
There really is no such thing as a high beam HID. Almost all conversion kits are 35 watts, lumen value is based upon kelvin temperature. Where you get High beam HID's is if you have a seperate high beam halogen housing that aims the light upwards and outwards, still the same amount of light output. If you buy a bi-xenon kit, depends if you get a cheap one or an expensive one. A cheap one comes with a high beam halogen bulb mounted beside the arc tube. The good ones used to have a mechanical device that moved up and down the tube to re-aim the light. Now they come with two arc tubes per sideand four ballasts total. But those only work for single headlight housings. I didnt know if you knew this already or not, just thought I would share.
Old March 26th, 2008, 11:43 AM
Yea i pretty much knew that it was the same output just the direction of the light was different. In my truck i have the seperate high and low housing in the headlight. They are right beside each other and that is why i wanted then both to stay on when i turned on the high beams because the amount of light output would be ridiculous. but i found a cheap way of doing this without cutting up the wiring and it doesnt cost as mch as thebright box.
It's only $22.99
http://www.jcwhitney.com/HighLow-Bea.../600002852.jcw
Old March 26th, 2008, 2:38 PM
northey87's Avatar
Letus know how well this works, because I have seen them before and have been wanting to try it in my '95.
Ryan Brickel
May 12th, 2012 9:26 PM
white95suburban
January 23rd, 2012 11:03 PM
mykids08
October 24th, 2008 1:18 AM
donnyhinds
February 19th, 2008 11:21 PM
racerad
March 15th, 2007 6:55 PM
Quick Reply: Bright Box!!
Top
Follow Us
