Notices
A/C refrigerant leak
Old August 2nd, 2020, 1:10 PM
slowrida's Avatar
Default A/C refrigerant leak
Hello new to this Chevy forum. i own an old 2000 1500 silverdao 4.8L 4x4 and was wondering if there is a Known weak spot on these trucks that the 134a leaks from.
Old August 2nd, 2020, 7:39 PM
oilcanhenry's Avatar
Most likely the A/C compressor. Check your high and low inlets for a bad Schrader valve too
Old August 2nd, 2020, 10:21 PM
slowrida's Avatar
Yea, i did manage to charge it and it cooled pretty good compressor was running very quietly but it leaked out a day later. Im gonna look at the eval coil?? are there any known ac leaks on these trucks that keep popping up you know of?
Old August 4th, 2020, 7:25 PM
Gumby22's Avatar
On a truck that old, it could be about anything, but finding the source is not unlike finding any other fluid leak. Look for areas that appear wet or have dirt/debris stuck on them. If it’s leaking fast enough to lose the charge in a day, it shouldn’t be too hard to see.
It may help to remove the grill and air box to get a clear view of the condenser and lines.
If nothing else, get a UV dye charge to trace it - with large leaks, it’s easy to see the source without actually needing a UV light and glasses.
Old August 4th, 2020, 8:47 PM
There are all kinds of o-rings that go bad. I just hope its not the evaporator. That means pulling the climate control box and is one of the most expensive A/C components to replace due to all the labor involved. They don't go out often but they do go out on occasion. I'd try the leak finder first. If you pull the condenser just chuck it for a new one, like Gumby said. Get a new orifice valve with might come with the condenser, as its the lower tube on the condenser. Put some PAG 150 oil on it and gently affix it into the connection.How much PAG 150 did you add with the new compressor?. If you are REAL lucky it'll leak out and show you where its leaking but dont count on it as a new system only holds 8 oubces of oil..
Old August 13th, 2020, 5:46 PM
elkhornsun's Avatar
With my 1998 Tahoe the evaporator developed leaks and to replace it the entire dash would have to be removed. Labor costs made this an unwise investment.
Old August 14th, 2020, 11:55 PM
I am a fan of running everything every so often. For instance, using the heater on full in summer time for awhile. Gets all the antifreeze out of the heater core, so it isn't just sitting
there with nothing to do during the hot months and so on, Evaporators going out are usually the result of moisture/air in the system.
Old August 15th, 2020, 4:25 PM
Gumby22's Avatar
Or someone who wasn’t paying attention while assembling an HVAC housing, as seems to be the case on the rear evaporator in my 2016 grand caravan. We’ve owned it since January 2017 and it held out until this summer....
dobaroy
Avalanche
June 20th, 2017 1:53 PM
PastorK
March 1st, 2010 9:09 PM
peterz
March 25th, 2009 1:02 AM
Hbhalibut
June 8th, 2007 8:47 PM
albinorhino00
April 1st, 2005 3:20 PM
Quick Reply: A/C refrigerant leak
