Crank the keys?
you should be able to fit those without a leveling kit or cranking the keys, if you want the front end raised a bit and dont mind a little bit stiffer of a ride to the keys but if you dont mind spending a little extra for a nicer ride go with the leveling kit
Common misconception. Levelin kit doesn't give you a smoother ride. Crankin stock keys all the way up is a much better ride than crankin a levelin kit. Levelin keys are reindexed and allow for more crank, leavin less room between the upper arm and the droop stop. Suspension bottomin out and horrible tie rod/ball joint/ cv angles
thank you guys, im gonna be ordering my new tires and wheels soon and want to raise the front end up to make it look good. last question, do i need shock extensions if i crank the keys up? iv heard yes and no
I cranked my keys up and did need extensions. My old shocks were extended all the way out and my truck rode like a hay wagon. I replaced my shocks with Rancho's in the stock length (takes any guess work out of it) and bought extensions off of eBay for about $25. This was money well spent. Rides like a truck again instead of a hay wagon.
Fishinfooleric10@aol.com
Silverado & Fullsize Pick-ups
October 11th, 2012 11:47 AM
skillettxxx
January 6th, 2008 6:31 PM
