Disarming the Factory Alarm
I have a Viper Remote start system that was installed over 2 years ago. It worked fine until I had my transmission swapped. what its doing is you can start it with the key the normal way but when you try to use the remote it starts then turns off right away. Thats the same thing it would do if the factory alarm had been set off. I believe the fuel pump shuts off. Is there any way to disarm the factory alarm so I can start my truck from a distance?
knarva
Silverado & Fullsize Pick-ups
April 13th, 2013 7:23 AM
