possible nuetrual safty switch?
03 silverado, i have noticed that when i start the truck it lunges forward just a smidge. is it a NSS? i can also start the truck without putting my foot on the brake.
Last edited by jameseroot; December 8th, 2009 at 9:38 AM. Reason: adding signature
What do you mean by start the truck without putting your foot on the brake? Do you mean you can shift from park without the brake? Every vehicle I've ever drove you didn't have to have your foot on the brake to start.
If it slams into gear, I'd have it looked at, but if the truck just lunges forward I'd let it be. Hopefully someone else can give you their opinion. If you have doubts, get it checked out.
if you are starting it up cold, and in park and it moves forward a little bit? and comes back, it is normal. my 03 when the temps get down to like 40* and the trans fluid is cold it will do it also. just cold, thicker trans fluid going thru the system at start up.. sorry i cannot explain it better.
hope this helps..
hope this helps..
cjasonsmith
February 21st, 2009 10:50 PM
