wont start
wont start
02 chev silverado turn key on fuel pump starts but when you turn the key the lights on the dash and radio go out, wont turn over.relay cliks in fuse panel but starter wont turn pls help
RE: wont start
This truck has done this 3 times before but has allways started after leaving it for awile, tried going through the search but can't find anyone with the same prob.
RE: wont start
if its clicking the batter/altenator is prollytoast, it takes way more juice to start it then it does to keep it running, the lights dimming is the truck draining whats left for life in your battery, my guess is the battery just wont take a charge anymore, and before when it did it, the battery was on the outs, but the Alt kept getting some juice to it, but now its finally dead
could be the Alt not charging anymore either and you finally ran your battery down.....the truck will run for a bit even if the alt is nor charging it, but it will eventually go...when you turn the key to on where is your battery guage reading....
RE: wont start
This is becoming a dire emergency here...Its my neighbors truck (I have a 94...much easier ta fix!) He has no internet, we,ve checked the battery, starter wires etc. I wish I had a tech II handy. The truck has done this before and makes me think it could be security related. We will just have to sit here and drink my beer until it starts but by then we won't be able to go anywhere :-)
RE: wont start
TY for the help Malibumax, I checked the battery and alt with a meter and both were good...got the owner to roll it ahead and slam it into park...Truck started!...I asked him to drop the starter and clean up the connections and hopefully the prob is fixed.
RE: wont start
ORIGINAL: gec
Take the battery terminals (especially the positive) and inspect and clean them. Then reinstall them and be sure to get them good and tight. This will probably fix the problem.
sleepingciv
July 25th, 2020 1:03 PM
luvche
Cobalt
May 31st, 2014 1:44 AM
wildboy74ss
Silverado & Fullsize Pick-ups
April 1st, 2009 5:10 PM
