04 duramax turbo
Old Mar 8, 2010 | 7:44 PM
saskrider's Avatar
Default 04 duramax turbo
I have a 2004 Duramax and the turbo has a high pitched sound on acceleration, especially when cold. Power and fuel economy seem to be the same. Any ideas what is causing the noise.
Old Mar 8, 2010 | 8:00 PM
gotstylez's Avatar
just when you start it or all the time?
Old Mar 8, 2010 | 8:09 PM
maxxman04's Avatar
could just be the turbo spooling up. they make a high pitch whine that increases with throttle. it takes more to compress cold air. this is normal. if the power cuts out, or throttle response is not the same as normal, it's possible it's the bearings. you might also check the hoses at turbo and intake to make sure they aren't worn or cracked or loose.
Old Mar 8, 2010 | 9:09 PM
gotstylez's Avatar
thats what im thinking but its its only when he starts it up.. it could be seals and bearings and ehatever else.. probably needs a rebuild
Old Mar 8, 2010 | 9:15 PM
maxxman04's Avatar
my 04 whines more on start up. not much, but it is a little more than when warm.
Old Mar 9, 2010 | 6:25 PM
saskrider's Avatar
Thanks for your info, This only started about 1 month ago, I know that turbos do have a whine to them, but this is more excessive than I am used to. I have owned the truck from new. I had checked the hoses, they are all in tack. My thought was bearings, but if that was the case, the turbo should have blown a while ago as faulty bearings dont last long at the revs they are turning in there.
Old Mar 9, 2010 | 7:30 PM
maxxman04's Avatar
not necessarily. they might make noise for awhile before goin out. also, might check housing for cracks. does the noise go up and down with rpm, or is it steady?
Old Mar 11, 2010 | 8:47 AM
All_out_Chevy_Man_1988's Avatar
Do you plug it in when it gets cold? it might be that the fuel is too thick and can't flow right.
Farmer Bob
Sep 17, 2013 7:36 AM
nomad1
Dec 29, 2012 11:37 AM
UKChevyJules
Sep 23, 2008 5:42 PM
Jtrain
Dec 27, 2007 11:49 PM
FairTax
Feb 18, 2007 5:01 AM
