1993 chevrolet Silverado 1500
Old Feb 1, 2014 | 9:31 PM
chevy1993's Avatar
New User
Awaiting E-mail Confirmation
Default 1993 chevrolet Silverado 1500
I recently noticed I had low battery volts replaced my battery and alternator was okay but once warmed up when I put on the windshield wioers heat etc mt volts go down ive never experienced this before I noticed it the other day when it was really cold out and driving home from work got a brank new battery and alternator but if I have headlights on n turn on heat dash lights n headlights dim for a secons and go back to normal if I turn uo the radio as bass comes in I loose volts any iddeas on what could be causing this? Also does it in reverse help?
Old Feb 2, 2014 | 7:18 AM
Check all your battery cables for loose connections and corrosion. Check at both ends of the cables, not just at the battery. Possibly a bad ground somewhere.
Old Feb 2, 2014 | 7:56 PM
Chevyy 223's Avatar
Ill try that tomorrow thanks
Old Feb 2, 2014 | 10:04 PM
Chevyy 223's Avatar
I followed the ground from the battery to the motor looks like the previous owner painted it and got paint on the ground plus there's some rust in the nut looks like some snow hit it when it stormed should I remove it and clean it my self if so whats the best way
Old Feb 3, 2014 | 1:53 PM
Remove and clean everything with a wire brush. If the cable looks like it is bulging or corroded on the ends then replace it.
Old Mar 26, 2014 | 3:54 PM
mudcat5's Avatar
Realize this is a little late, however had the same issue. ended up beiing the battery terminal connector. replaced that and it fixed the issue completely.
sonny_bono22@yahoo.com
Sep 21, 2012 12:10 AM
SolomonMan
Dec 29, 2010 1:54 PM
MissElieMae
Mar 18, 2009 4:31 PM
sixpack_sid
Jul 30, 2008 10:55 PM
trolea1234
Jun 7, 2007 8:15 PM
