1994 1500 transmission problem
Old Sep 19, 2007 | 2:05 PM
shanep72's Avatar
Default 1994 1500 transmission problem
My 1994 1500 with automatic transmission is giving me problems. It start's out in first but won't shift out until I let up on the gas then it will shift I think into third, I checked the fluid and it's full but a little dirty I don't think the fluid has been changed in a while I don't think fluid is the problem could this be an internal problem?
Old Jul 16, 2015 | 5:40 PM
Porretto's Avatar
Default Chevrolet Silverado 1500
I don't have an answer for you but I just bought one and it's doing the same exact thing.
Old Jul 21, 2015 | 9:22 AM
gsferraro's Avatar
Trans should be a 4L60E, If its shifting from 1st to 3rd, then your band is no good. Cant do much on the outside except pull out the servo piston to check the rings, pretty common for the band to break though. Gary(i have a trans shop in new york)
Old Mar 4, 2021 | 10:22 PM
Nick Wrye's Avatar
Default 1994 1500 4x4 z71 5.7 4l60e trans wont shift after trans change
I have a 94 Z71 with a 5 7 I just installed a new/ used 4l60e that I I bought from my buddy out of a running truck. the truck was running and driving when he pulled the transmission and sold it to me. when I installed it into my vehicle all it does is High Rev and no gear shift what can it be
flewster
Jul 28, 2021 2:20 PM
floored327
May 27, 2021 10:41 AM
Tyger255
May 31, 2019 9:58 AM
mwade
Jun 12, 2011 1:06 PM
srothery82
Dec 29, 2010 1:45 PM
