1996 K1500 Flasher Problem
Old Sep 25, 2011 | 8:16 PM
wadeh's Avatar
Default 1996 K1500 Flasher Problem
My flasher in my pickup just started acting up. It keeps intermittently clicking, similar to the noise it makes when turn signal is on. Clicking stops when brake pedal is depressed. None of the lights are flashing unless selected to do so. I bought a new flasher and problem still persists. Similar threads indicated a possible bulb by fuse box or glove box or the multi function switch may be bad which is expensive.
Will it hurt anything to continue driving as is? I only use the truck occasional for dump trips etc. Can put up with the noise as long as it will not cause any problems.
Last edited by wadeh; Sep 25, 2011 at 8:26 PM. Reason: Found info from similar threads
sportlight82
Jul 25, 2009 3:24 AM
dozer
Mar 12, 2008 9:51 PM
yzman720
Apr 15, 2007 3:13 PM
kimmmba
Jan 10, 2007 8:31 PM
kimmmba
Jan 10, 2007 8:20 PM
